SOS - See workshop resolved
Hi Alex, I have the sos battery issue, got myself the obdeleven pro plan and have tried to follow your instructions to clear the fault. Trouble is i dont see a search option in telematics so cant get to the Backup_Battery-SoH or the next step, "used basic settings" - "Resetting the history of the emergency call battery". Am I missing something? Would appreciate some help on this cos its driving me mad :)
Of course, let's just try checking the simple checks for the obd - so the key is engaged on, the ignition is on but the engine is not on. Make sure the hood is open first. Then control unit - telematics - basic settings - reset emergency call battery.
If that doesn't work have you checked the logs to see the battery soc? It may be the battery issue flat
Mate, thanks for your time on this. It has cleared the fault and led is green again. Happy days.
Thanks for the great advice, VW were rubbish never even getting back to me, a VE specialist quoted £1400 for a module of some description, but today I bought a OBDeleven and it worked. For those struggling make sure you click the vehicle icon at the bottom, this is where the battery reset is and don’t look on the home page like me.💪💪💪👍🙏
Good thread, thanks very much to the OP and contributors. My iD4 had this SOS battery fault for weeks. Have sorted it with OBDEleven which even has a one touch app feature specifically for the SOS Battery fault. Which tells you that loads of people have had this issue. Cost me maybe £120 all in which is a lot less than walking through the door of the VW dealer.
(I do have VCDS but it won't work on the iD4)
Hi Alex
Do I need the OBDELEVEN PRO to reset the SOS BATTERY on my T6 2021 or will it reset without the subscription?
Many thanks
You need pro.
Could be right for a T6 but the iD4 was fine without Pro subscription. Used OBDEleven 3 and bought credits on the OBD website. Needed 100 credits to use the one touch app for the SOS battery reset. I didn’t find the OBD website very clear but got there in the end. It was cheapest to buy the device on Amazon and the credits direct from the website. If you buy the credits through the app they cost a lot more. There’s an explanation for this on the website regarding Apple or Google adding a premium if you make purchases through the app.
In any event it should work and will be well cheaper than walking through the dealers door.
Also look out for discount codes- there’s been some good deals recently
Hey - So to check the battery level State live data, Plug in the OB11 - Give it a scan - then open up module 75 ( telematics). Once in there just use the search bar at the top and type in like "Battery" and you will get Backup_Battery-SoH.
Then you will be able to see the actual live parameters.
So for mine, the battery was showing a 90% battery health and was fine.
I then just "used basic settings" - "Resetting the history of the emergency call battery" - Ran that.
Then did a normal Fault clear and it still seems to have worked.
Im not a sparky/diagnostics specialist but id imagine it is triggered but voltage drop or something along thoses lines, and as a safety procaution id imagin the data reguarding the battery state is stored in the telematics module so just retriggers if it is not reset before clearing? Maybe someone with better understanding could explain the actual protocols but that appears to have worked for me
Merci Alex. ça a marché super
Hey - just had a little look, couldnt see a one touch for this - so i think the pro will be needed! :)
Thanks Alex , following your indication and with an ODB11 I finally reset my SOS problem ( green again…!) on my 2021 T6.1.
I spent 4 months fighting with VW dealer with no solution at all from their side.
They really didn’t know how to solve the problem … a shame !
Unfortunately there seems to be alot of people having this relatively minor issue with no help from VW happy camping ^^
Thanks for this. Must admit, took me a few goes until I read the but about opening the hood 😅.
So glad I found this thread as I’ve had the dreaded red SOS light for over six months and was at the point of paying a lot of money to get it fixed as it was driving me mad seeing the fault every time I got in.
£40 spent for the OBDeleven pro plan as I had a device (discount code slix for 20% off) and now I have a green light and no annoying message. Absolutely chuffed
Mine went in for a warranty repair for this today and they’ve just called me that they’ve charged the engine battery and it’s resolved it, so they’re not going to replace the SOS battery. I feel a bit fobbed off because I’ve been waiting for them to sort this out since collecting the van back in march. They’ve basically said I’m not driving the vehicle enough to keep the engine battery high enough to top up the SOS battery.
That could be the case and might not be a fob off.
Not all vans suffer (my '21 hasn't, but I keep it on a maintenance charger), and while the OBD11/VCDS backup battery counter reset works on many its not a universal fix. Some do indeed simply get upset because the vehicle system voltage is insufficient over a period of time.
But yes, they've left you dangling unnecessarily. They could have done this in March.
