I’ve now had confirmation and date for new suspension.
So I’m putting up the SoLow’s for sale. They won’t be available until
after the 8th of August though. Might give someone a bit of time to save some pennies.
As you may know that these are one of the lowest setups out of the box and are very comfy at their highest. I’ve ran these at the top and I’m now running them fully wound down at the front and about 10mm left at the back with 19s. I’ve also ran them with 18s and 20s! Although I wouldn’t recommend 20s unless you want a non load rated tyre or no arch liners. I’ve ran all sorts of tyre and wheel set ups so just ask and I may be able to help you with what will work and what may not work.
These were fitted by bognor motors around mid April time and have only covered around 1K miles.
£1050
£1050
Transporter Lowering Kit - T32 - T5/T6 | So Low Suspension
Grab a Transporter lowering kit and find out what it truly means to drop it like it's hot! Your Transporter will be looking it's very best, all the time.
solowsuspension.com
