Skyline pop top & SOS fault
Drebin
Hi all, hope you can help.
I have a t6.1 with a skyline pop top, as part of this they relocated the aerial to the back of the pop top.
Recently I've been getting the sos fault and to take it to vw. When I rang them they immediately said it just needs the update.
However after them having it for most the day they said that they would not do the update as a fault code was coming up saying that the aerial was not connected (something along those lines). I asked how this would be possible if my radio works fine, phone calls etc as well as the sos intermittently. But they blamed this for the sos and not the required update.
Has anyone had this issue or can help? Feel like I'm just being fobbed off by them. I spoke to skyline and they said its literally just a plug in adaptor so not sure where I stand.
Thanks in advance
I’m afraid I would take the VW view here. If the SOS is showing as not connected, and Skyline have relocated it, then Skyline need to fix it.
The radio arial and SOS are different things, and I would expect phone calls are using Bluetooth/CarPlay to your phone rather than roof arial (again very happy to be corrected here).
What I can't understand is how it sometimes works and others times doesn't. You would think if it was disconnected it just wouldn't work
Hey, I’m currently looking into getting a pop top for my 6.1 and was considering skyline. Has your issue now been resolved? If so how was it fixed?
Thanks in advance
Hey, did you manage to solve your issue? In same position, am likely going to contact skyline as well.
Hello everyone, I’ve the same problem - intermittent issue with SOS warning light. Anyone get an resolution?
Hello everyone, I’ve the same problem - intermittent issue with SOS warning light. Anyone get a resolution?
Hey I have the same problem. Pop top was done summer of 2022, had an intermittent fault for the last year or so & now every time you start the van it’s a fault. VW won’t touch as diagnostics said it’s the aerial not connected fault. I’m tempted to get a new aerial & plug in at the connectors at back of pop top & see if it’s that end, or try and find the other end in cab to connect there. Let me know if you get to the bottom of it!
Interested to find this thread...
Experiencing something similar.
Was ast Skyline Somerset on Friday. I had my 160w semiflexable solar panel replaced by Skyline on a warranty claim (they installed the OG panel when the Skylow roof was installed in 2022).
Shortly after collecting the Van I had the same "SOS Emergency Call Restricted" message. I didn't think too much of it, assuming it had maybe accidentally been pushed by an engineer when the work was done. It was only when I got home I realised it was actually registering as a Fault.
As it was Saturday by this time, I called VW Roadside Assistance - they gave me the spiel about 'Software Update' although they did advise me I had the latest software according to their system.
Monday, today, I called my local VW Stealership (who I despise because they are beyond useless) they advised it they had a three month wait on appointments... Yes that's right... A three month wait
So out of desperation I took it to a trusted independent garage this morning and they ran diagnostics. They could see that the Fault on their system and despite trying to clear it, it just came back straight away.
Initially I thought it could have been an intermittent malfunction with the Ghost Immobiliser as they do sometimes generate random fault codes.
But thinking about it (and reading this Thread) I'm begging to suspect that when the solar panel was swapped and the cabling adjusted, either the antenna wasn't connected up correctly or something has been damaged in the process.
I'm gonna call Skyline tomorrow and make my case. They've always been very fair in my experience. It seems highly likely this is the root of the issue - I hope they agree
Keep us updated! I too will be ringing Skyline shortly. VW don’t want to know for me as the aerial has been relocated but did say they’re diagnosis code was aerial connection.
I’ve thought about how to test it at home with getting a new aerial then connecting at connector at back of pop top to see if that fixes it. The other end of cable is behind the dash I think but I’m not that brave!
Interestingly someone on Facebook had a similar problem but his was intermittent & faulted when road was bumpy for example. He ended up with a new extension cable put in.
Mine produces the warning from the get go and like yours instantly pops back up once I clear the warning.
Like you we have a solar panel with the cabling for that going through a rear grommet. The aerial cable is very thin, I wonder if it’s being pinched too much through this.
I suspect you're right on that one - I wasn't aware that the cable was on the flimsy side - that would explain it for sure.
Not surprised that VW didn't want to know - whilst I on the one hand understand their reluctance given it's aftermarket mods, generally I've never known such an unhelpful company! They continue to shock me.
I'm going to have a good look tomorrow at the loom to see if there is any obvious issues with the connections. The problem might be staring me directly in the face.
Now I've spent the day thinking about it logically - I'm shocked that I didn't connect the dots on this one!!
Question for you @lauraj
Assuming your SOS button on the roof of the cab has the Red light illuminated (not green as it should be) are you still able to make SOS calls?
My SOS light is Red but if I press the button it starts the process of making the call (you have the opportunity to cancel for 10 seconds) Which suggests that despite the Error message on the Dash - there is still enough reception to make an SOS call
Hey sorry didn’t see this post. Yes I think it still goes through, will double check tomorrow though. Have you had any lucky with Skyline?
Yep starts making emergency call once pressed, I manually stop before connection but light still says red afterwards
Yes all good news!
I called them and discussed the issue. They said it was more than likely a loose connection or possible but slightly less likely, that the Antenna was no longer earthed.
I took it back down to Somerset last week, parked up at the Industrial Unit and within 10 mins it was completely sorted. As expected it was a loose connection that was repaired very easily.
Absolutely faultless service from Skyline. My only complaint is that I had to repeat the 3 hour round trip just for a few minutes of work. That said I'd rather it be a simple fix that's done in no time than a major job that requires some serious repair work.
Very happy didn't have to get VW involved, that would have been heartbreaking
Yes all good news!
Excellent news!!! I will get in contact, they have been excellent in repairing some minor niggles (cam lock creaking when cornering and pop top shifting forwards out of alignment).
Just updating the post:
We took our van back to Skyline to investigate the SOS fault (aerial connection fault on diagnostics). They took a look at the extension cable & joins, and there were no issues they could see. They suggested replacing the aerial fin but don’t hold stock (they only move existing ones) and kindly offered to replace it once we had sourced one.
A few months passed and I just didn’t get round to purchasing an aerial but out of the blue the fault has disappeared (bear in mind it has been red consistently for well over a year). Our SOS button has remained green now for around a month. We haven’t had anything else done to the van (i.e. no service or software update). So for now, we’re ok. If it plays up again I will purchase a new one and get it booked in to Skyline to replace.
Thanks in advance
I had the same issue but mine started before the Skyline pop top was fitted. It seems to be a loose connection in the overhead panel or thereabouts. Mine seems to have "gone away" for now but occasionally it returns... like when I pushed on the top centre of the windscreen, in order to stick my dashcam next to the rear-view mirror.
There are two connectors behind the plastic cover below the mirror around there. When I had these unplugged to get behind the headliner, the SOS call warning was on. You could check that they are firmly plugged in and clicked home on yours.
The plastic cover comes off in two parts (T6.1). I took the little top one off first, by prising the sides outwards.
Hopeful final update from me:
Ofcourse the fault reappeared. I purchased a new aerial fin direct from VW for £96. Popped back to Skyline who tested it on the back & made no difference. Turns out the extension wire has gone faulty.
They said they couldn’t replace the cable in situ & have more recently realised there is enough room for it not to be relocated. So new aerial has been put basically where it was originally at front & sits under pop top. One at back remains on as a dummy else would leave a hole. At least I don’t get the annoying red light & fault ping anymore! Skyline have been great at remedying though & got them to service pop top anyway for £99 at same time.
