Hi,
I have electric sliding doors, both sides. I also have autolock over 20km/h active, so each time I drive they are locked. However I've noticed some time ago that left ones need to be unlocked twice to allow opening, while rest (front and right ones) are "ready to open" after one unlock. It does not matters if I unlock by turning engine off and removing key from ignition, using internal button or unlocking via key fob.
I've scanned via VCDS and found only one issue (probably) related - fault code: 03303 but no idea what could be the problem. I thought about door lock mechanism connection problem but it works each second time, so it's probably not that.
Additional info - I'm not sure when it started, but definitely it was working "normally" on first unlock some time ago. Not sure if it may be a configured via vcds (maybe I've messed sth somewhere the other day?), completely no idea...
