Hi all, I've noticed again this winter as the temperature drops away over night, the inner windscreen has a fair amount of moisture - enough to have to use a 'T' style squeegy and a paper towel to remove the excess before driving. I'm thinking there must be moisture within the van somewhere in order that it happens. I know this van inside and out now, I've had it apart so many times and I am only aware of an area of slight moisture within the bottom of the o/s rear panel behind the back wheel (pics attached). Nothing has been spilled and it's been vapour barriered throughout the rear. The cab area is totally standard other than for a leisure battery and electrics under the drivers seat. Care was taken to route the cables through the N/S main bulkhead grommet.
I park forwards against the front of our house so I know it can get cold and it is North facing so doesn't see much temperature rise in the day time. I've never had this issue with any of the cars I've had so I'm just curious as to whether its something that effects other guys vans? I wondered whether there could be moisture in the drivers floor mat but they are bone dry. The pictures show as I found it, and after wiping away the residue. I wouldn't say it was 'wet'. Is this a common problem or just a winter one?
2018 Highline PV Day van conversion. Thanks for your thoughts, Russ
