Roof Bolt Hole Dimensions Lwb T6
comptek
Can anyone tell me exact specifications of the roof bolt hole spacings on LWB T6 please?
I cant find the specs on VW's website anywhere and getting up on the roof and measuring them is not very accurate with a tape measure! What im having made is being cnc'd so i need very accurate specs!
Any help much appreciated!
I can measure up our lwb t6 van roof....
But it would be a tape measure job.
What measurements did you need and for what?
Got a pic of what u need?
That's really helpful thank you, I'll do the same and that if were are about the same then ill be happy! Im making frame to hold 2 x 100w solar panels. Centre to center across the vehicle width, A and D, and centre to centre on both B and C
B- 350mm
C- 670mm
A- 1310mm
D- assuming same as A
bit tricky doing it with a measure tape on me own . . . . . =]
B- 350mm
C- 670mm
A- 1310mm
got the same dimensions for B and C but A was 1280 for me,got a 2014 transporter in Mexico, do you know if width of the van varies from countries?
