RESOLVED: EGR Replaced - No Cruise Control And Weird Display Readings
Noobydooby
Hi Guys
Got a problem.
Im selling my T6 (2016 - 102 T28 with 57000k) and had a diagnostic done showing:
P040100 - EGR flow insufficient
Had a totally new EGR, engine flush, oil change and service - Then it showed
P144000 - EGR Vaccuum regulator solenoid valve open circuit
P040500 EG Recirculat. Sensor A Circuit low.
Codes were cleared and parameters were reset and the engine light is now off and there are no error codes.....so far.
Only remaining issues are:
1) Cruise control no longer working (don't actually know if it was working before, never used it)
2) Display readings are wild - for example I'm getting mpg readings between 8 mpg and 200 mpg changing rapidly as im driving.
3) Display seems to have gone crazy with its readings generally - fuel ok, oil temp ok, trip computer ok.
What are my variables?
1) Had 20" wheels put on.
2) New EGR valve.
Can anyone help me with this? I cant afford to throw much more money at it and id like it right for the customer.
Thanks.
Hi Guys
Got a problem.
2) New EGR valve.
Thanks.
Mpg set to instantaneous instead of average
Hi Guys
Got a problem.
2) New EGR valve.
Thanks.
If it’s cruise that works off the stalk, check the switch hasn’t been turned to ‘off’.
Did the battery get disconnected when the work was done ?
Check that everything was re-connected properly including earth connections.
Pete
Those initial faults were probably cause by the row of valves above the engine being disconnected.
I would also check the one touch windows are still working.
well the chap plugged back in and reset - also reset parameters to a new egr - everything seems ok at the moment.
My background is classic minis - so the VWT6 Thing is a new world.
Thanks for your patience guys.
