Replacing Bulk standard relay with victron smart dc dc charger
stevieg21
Hi All, my T6 has this under drivers seat. I’m thinking that when ever my ignition is on the leisure battery is simply connected to my starter battery. ¯\_(ツ)_/¯ My Researching is leading me to swap this for victron smart dc dc charger. Quick questions 1. It’s a Straight forward swap and suitable? Two small wires (ignition on), two big cables from starter / to leisure battery. 2. Should I get Isolated or non isolated? I guess the one with 2 negative connections? 3. Victron do 2 models 15 or 30 amps?
Thanks in advance
It’s a 66 T6 blue motion so smart alernator. 95ah AGM battery under drivers seat. It will be a squeeze in there but it should go. I just want to go away for a wknd and run my fridge (domestic crx50) and lights, nothing major needed. Also running solar but I’ve got the victron solar controller in the back.
1- yes
2- either, or. non easier as only 3 wires
3- 15A is fine for 100ah AGM. Get the 30A if you plan on adding a second battery or swap to lithium.
I think I will go down this way. Just changed my 120ah leisure battery after 5 years. Mine is a T6 so smart alternator? Just have the basic split charger similar to photo.
Just one thing to point out ... for anyone reading this thread, it will not work for a California Beach or Ocean as the relay also closes to charge the starter battery. If the relay is replaced with a DC-DC Charger then charging the starter battery by plugging in the "shore power" no longer works. VW in their infinite wisdom have a charge device on both sides of the relay, the 230V charger on the Leisure side and the Alternator on the Engine side. Splitting off the 2 leisure batteries from the starter battery on my Ocean is giving me a real headache.
