Removing speed limiter with Obdeleven
it possible to remove the speed limiter from an ex RAC T6 (2018) with Obdeleven? If so, can somebody please explain how?
I am not brand new to this kind of thing, just very rusty. Until 2011 I ran my own mobile mechanic business and had VAG-COM which I used regularly to code equipment. I still have the hardware somewhere but don't own a windows laptop to run it on. I also fear the cable would be so out of date it would probably be useless!
I have OBD eleven which I have only used so far to read fault codes on my own car so am not as familiar with it as I once was with VAG-COM. I am happy to pay for credits / a pro subscription if I need to.
Thanks.
Try the following:
Control units > Engine > Adaptation > in there is a channel something like "Adjustable maximum speed limit"
change it to e.g. 300 km/h (factory value) press and hold "write" button.
Let us know if it's then limited to 300 km/h ;)
EDIT:
Try the following:
EDIT:
Thanks, seems easy enough - I will give it a go and report back. Perhaps though, if I set it to 1080000000 it might be capable of time travel?
I finally picked up the van this afternoon, did as you suggested and it worked perfectly. Thanks for the input.
Did you use odb11 and what app because I can't seem to find it anywhere on mine? Any help would be much appreciated!
