Re. your driver's seat squeaking- is it noticeable more when going round corners?Yeh, noticed that a couple of weeks ago, but it seems intermittent. Thought it was the cupholder. Had a noise from new on the drivers side, again intermittent, sounded like a bad electrical connection, crackling but it would go away if I put my hand on the top of the steering wheel. Not heard that for months now though. VW vans were once renowned for their lack of rattles, not so any more. My drivers seat also squeaks every now and again.
Didn't do anything special really, just gave it a good wiggle to try and create some space between the dial and the surround. It seems to have worked though!Yes @CRD tis only when I go round bends. How did you remedy it?
mine too did this so wedged a piece of card in, no rattle now.I have noticed quite an annoying rattle from the passenger side it seems to be coming from the little tweeter cover part of the a pillar or from inside it. Has anyone else experienced this?
I've an annoying rattle coming from the trim under the steering column, does anyone know how to remove this?
@Amped I had the exact same rattle, drove me nuts, was constantly holding the bit of plastic to stop it. The fix; pop it out, spread the 2 metal clips that hold it in place, pop it back up, hey presto, it doesn't rattle anymore.2nd T6 and same rattle had appeared on the flat piece of plastic on the underside of the overhead storage!!
That sounds like a squeaky bed!My squeaky drivers seat has come back with a vengeance. This is the sound that tortures me every time I turn a corner (I'm rocking on the seat here). Highline with heated seats.
Has anyone managed to cure the squeaky drivers seat? My Caravelle drivers seat squeaks when I sit down and if I move around. Checking if there is a simple solution before taking it back for a warranty fix?That sounds like a squeaky bed!![]()
