Radiator Fan running when engine switched off
Darrenlm
my radiator fan has started to run when engine switched off, coolant level looks fine, engine oil looks fine, no warning lights, temp is 90 on the dot, could it be doing one of those Re-Gen things? how do I know if it is or how do I know if its something else? thanks
T6 - 2018, HIGHLINE, 150 manual
There's no warning lights. You can check with Carista the status of thr DPF but there's nothing to worry about. The regen will restart next time you dive if it didn't finish. If the issue persistent a good run of 30 or so will help.
