can anyone recommend a good one please??
Thanks.
Thanks.
There are several different types of machine polisher.
Duel action and Rotary being the most commonly used, and they range from very cheap, to very expensive as with most things.
However, without sounding condescending, or at least trying not too. Anyone that thinks they can just pick up a machine polisher, and 'buff' up their paintwork need to carefully consider if this is something you are competent in doing. It will cost more for a professional detailer to rectify a poor attempt, than the detailer doing the job in the first place. Specially of you're working with darker colours, this takes a huge amount of knowledge and skill to get right, and not leave holograms, buffer trails, burnt edges and so on.
I use a machine polisher pretty much 5 days a week, but the surfaces I work on, are not the same as a car, so i'm not in the best position to advise on products, but I know enough to know a DA polisher is safer to use on paint than a Rotary, if you are a novice.
We use Rotary simply because we need a very aggressive machine to cut out the issues we fix on fibreglass and aluminium.
I've always used the Dewalt DWP894X polisher. It's a very balanced and very powerful machine, and although it's quite a heavy machine at just over 3kgs, it is super reliable, and only ever needs brushes now and again, and the odd speed control module if any water gets inside the main trigger. They are around £150-£200, and available from Machine Mart. We have 6 of these, and 1 of them is nearly 10 years old, and still sounds as good as the newest one.
@T6180 might be able to help a little more, as he's just gone through all the research on machines, and spent a small fortune on stuff to do his HIMSELF well away from any locations in Leicester
went through the clear coat and down to the bone in about 5 seconds.
Lesson learnt the hard way.
All the best lessons are learned on someone else's carI used a 110v Portercable for a few years back when I was really into detailing, great machines, but I think there are better options now.
I progressed to a Metabo rotary, the first time I used it I helped my bro take a scratch out his rear wheel arch on a 4 week old Range Rover Sport, went through the clear coat and down to the bone in about 5 seconds.
Or go to a local converters, ask for window cut outs or a roof to practise on
You ever seen that scene in 'Final Destination' where the kid is stood next to the train track and that sheet of metal gets thrown up by the train?
Depends on your budget? I would have a look at the Forensic Detailing Channel.can anyone recommend a good one please??
Thanks.
