OPS / Parking sensor / PDC retrofit not working
andreis
Hi,
I retrofitted front fog lights and Front&Rear OPS parking sensors on this van. Fog lights work ok, but parking sensors are not displayed on MIB unit, only a black image appears when you press parking buton or when you engage reverse gear. I checked all codings/adaptations, seems in order.
Find below the full scan.
Any help/advice is wellcomed!
  • Log-VW CARAVELLE-WV2ZZZ7HZJH049012-251280km-156138mi.txt
Coding in 5f and 10 need to be checked for OPS/Optical display. Sounds like RVC may have been coded by accident?
Thanks for your support!
I checked and let another colleague to double check, seems ok. 5F is a Mib. maybe is a coding here that needs to be changed, i checked this coding from another car and there it was working.
Please find attached the photos with codings/adaptations and what it looks like, when you put in reverse or push pdc button. The only Adaptation that I could not do, is channel 30. find in photos.
Please post adaptation map from 5F-Infotainment.
VCDS > Applications > Controller Channel Map​
The result will be in file adpmap-5F-... in folder C:\Ross-Tech\VCDS\Logs\
hi,
please find attached the admap
  • adpmap-5F-5C0-035-680-F_WV2ZZZ7HZJH049012-20230306-0938.CSV
There are the following differences between factory setup (though with rear view camera) vs. yours (rightmost column).
First I would try to adapt the three last lines as here in green. The grey ones shouldn't relate to this :unsure: - maybe?
Besides the above you could try the factory adaptation below in the 10-Park Assist itself.
I'm afraid T6 can't do this - would need electric power steering.
Hmmmm....
"T6 can't do this" - I think I need to start my new retrofit thread soon :whistle:
  • Love
Reactions: mmi
hi,
many thanks for yor help.
View attachment 191113 - i tried, but no result
finally carsystems replied to me, i used what they recommended, but no result :
5F Coding recommended by carsystems:
Adaptation Channels
(11)-Car_Function_Adaptations_Gen2-menu_display_pdc change to Activated -IT WAS ALREADY
(13)-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high change to Activated-IT WAS ALREADY
(19)-Car_Function_List_BAP_Gen2-parking_assist_0x0A change to Activated-IT WAS ALREADY
(20)-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus change to Terminal 15-IT WAS ALREADY , I TRIED BEFORE WITH ALL OPTIONS
(5)-Car_Function_List_CAN_Gen2-PDC_audio_lowering change to Available- IT WAS ALREADY
(6)-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus change to Suspension data bus - THIS WAS NOT USED BEFORE, BUT NO RESULT . ANYWAY, CAN BUS IS CONNECTED TO t73B PIN18, 19 ,WHICH I THINK ARE POWERTRAIN DATA BUS
i will try tomorrow with all datas from youe second column.
thanks again, I will keep you up-to-date.
Reactions: mmi
hi,
Adaptation Channels
Hi,
problem SOLVED.
I changed adaptations as in 1st column you sent to me, then changed coding in 5F 1st byte and problem solved.
I will make tomorrow a full scan for codings and adaptations for module 10 and module 5F, to serve as support if some body need.
Hi just following the thread. Did you ever post how you finally got it working as it would be helpful to know ?
