No MFD, radio or window power [Resolved]
Niall.b
Hopefully someone can shed some light on my issue, i've no MFD, no power to the radio or windows. van starts but cuts out after 2-3 seconds.
Have checked the 5 amp mini fuse in the lower dash and it seems ok. swapped it with another one and no change. all remaining fuses seem ok
Issues just started after installing the module and wiring for powerfold mirrors.
Have you got any CANbus connections to that module? If so are they the right way round? Any wiring diagrams?
cheers for your reply. there's a constant power and a switched power to the control module. the other wires are to the mirrors themselves and splice into the drivers door central locking. the mirrors are working fine, tilting as the key fob is pressed to lock/unlock. took the constant feed from the back of the fuse box and the switched from the rear of the lights switch. quick check and wipers, lights and central locking working ok. all help appreciated
problem sorted, 30A under the bonnet and a 7.5A in the middle row under the dash, happy now
Reactions: mmi
