Hi what size wheels are these and tyre profile please. I’ve got a 55mm drop front and 40mm rear on standard 16” Claytons but I want to change to 20” if possible. Thanks
I don’t quite understand your question? I see you are a suspension specialist so please enlighten me in what I’m doing wrong
As for the load I’m a plumber so I wouldn’t say it’s loaded? The usual tools and materials.
Hi Ya a correctly set up van should have the same height front to back ( centre of the wheel to top of the arch ) if this is level then the van chassis is actually 40 mm lower in front than the rear . these measurements are done on the Sill.
There for 55 at the rear and 40 at the front will give a rake forward of 55 mm instead of 40 ???
