Lashing point location?
Welsh Tim
I am in the process of fitting tie downs to the rear of my Kombi, When the van was converted from a panel van the conversion company used a one piece ply floor. Does anyone have the measurements for the location of the threads or advice on how I can locate their positions before i end up with my floor looking like swiss cheese! Thanks
I’ve only had to deal with one following a bodged repair at the dealers. This is what they look like underneath.....you may be able to carefully drill a pilot hole from underneath. This is a front one behind the drivers seat. I expect others will look similar.
Regards
Ian
My vans floor is plyed then vinyl. I want to make a Kombi bed system myself (joiner) but don’t want to take up the floor to find the lashing points.
What’s the easiest way to work it out?
thanks in advance
Underneath the floor there are captive nut brackets riveted on - I had to re-tap one of mine. This is the one behind the drivers seat. You should be able to find the others to go up through the floor from underneath (after removing underbody protection)
Ian
Hi All
I have a van converted to Kombi. Ply floor with Altro flooring. I want to find the rearmost lashing points (barn doors) so I can secure camping goods etc. Anyone know the location points where I can drill through the floor from top to find the holes? Then I can open the holes to fit the cups and bolts? I know I can take underfloor panels off but I don’t have the room or location to do that - main road!! Thank you
These 3 photos from our build show them.
Pete
