Just Kampers 45Lt 12v-230v Electric Compressor Cool Box Fridge / Freezer £190.00
Sorry don't have a pic of it in my van, above is website picture.
Collection from Cumbria.
Website spec:
Quality Just Kampers product, exclusive to JK. Designed to be fantastic quality and fit nicely inside your camper, our portable fridge freezer has a 45 litre capacity. Capable of running on either 12v electricity from your vehicle’s ‘cigarette lighter’ outlet, or on 240v electricity from the mains, it’s ideal for long weekends away or longer camping adventures.
It’s strong enough to also be used as a seat and a table, which makes it ideal for use inside your van, where space is always limited.
At a glance:
• Designed and created by Just Kampers, using our decades of experience with camping and campers,
• Supplied with cables for 240v or 12v electricity, to offer you flexibility,
• Can be set to between +20ºC and -20ºC, using the digital control panel,
• Three-level voltage protection means that there’s no risk of it harming your vehicle’s electrics,
• Strong enough to be used as a seat or table, portable enough to be moved to outside your camper.
Size and weight:
Measures 69 cm by 34 cm by 45 cm,
Weights around 16 kg when empty,
Internal capacity: 45 litres.
Our portable fridge freezer is good to -20 degrees Celcius below ambient temperature. There are two compartments inside, with the larger of the two being useful as either freezer or a refrigerator. The smaller area is more like a coolbox and is always slightly warmer, making it suited to storing fruit, salad etc.
The fridge has built-in low voltage protection and also has an efficient internal LED light. This low draw compressor cooler has temperature settings from +20°C to -20°C, and a simple digital control system located on the front.
The JK 45-litre Electric Compressor coolbox can be powered by 12V and 24V so will run in most cars, vans trucks and buses. The power adaptor which comes with the fridge means it can be mains powered with 100-240v. It has a 3-level low voltage protection function with the temperature displayed and all set on an easy to use control panel. Celsius or Fahrenheit can also be selected.
Two modes can be set for either ECO Mode or High Speed. Internally it is lit with a bright LED light and split into a separate fridge/freezer and cool box zones. Includes one metal basket.
• Capacity: 45l
• 69cm x 34cm x 45cm (LxWxH)
• Power from 12/24 volt car battery
• 1.2 - 0.5 Ah draw (low power drain)
• Mains Supply (UK plug) and 12v Cables Supplied
• Rated Current DC(A) 5.0A (12V)
• PSU 100 - 230V
