Okay I have looked and nothing is current or up to date in threads that I can see. I'm fearful this will end up stuck in the unanswered threads section all the same
Am stuck
I need someone to tell me what warm white puck lights to buy to install on/in my ceiling panels. I don't want to spend more than £20 ideally and if I can get em on amazon that'd be great as I have prime. I haven't got a hole saw either so surface mounted would be best.
I've got some 2.5mm cable on order and have pulled interior out so have access to run cable.
Do I need wagos to wire in the lights (in parallel) or are micro junction connectors better?
Also, I have 16mm cable left over, can I use this from B2B/MPPT to 12v fuse board or is it too big?
Should I try run conduit and a pull cable for solar? Or is it better to do this when the pop top is installed? Not gettin a pop top til 2026/27...
Am stuck
