When you subscribe to be a VIP member. It’s about twelve quid if I remember correctly.When will I be able to access the vip section ?
Hi would you be able to share / send me the link please - I have to tackle this job this weekend once I found a replacement manifold. Thank you in advance.There’s actually a tool in the workshop manual to loosen that one bolt. Weird U shaped spanner thing, but I think you can still get to the bolt with an ordinary spline bit and socket and extension. Gonna remove mine next weekend. I found an online only free access workshop manual that shows you the steps to remove the manifold
Hi was this price quoted from a main dealer??I ended up booking it in to be done as can’t be dealing with the stress lol. £ 850 part and labour so not too bad I guess.
I had mine done recently and it was £1,200. It was done in Camberley.Hi was this price quoted from a main dealer??
VW commercial approved workshop. I had an intermittent start up fault from the van being 3mths old (it’s a 2018).Was this a main dealer, thinking of doing it myself, I had one fitted about 5 years ago by VW York under warranty but I think it has clogged up again, it looks a bit of a bad job so swaying towards taking it back to vw york to get another one fitted, not ideal but I suppose that is just how they are
The jobs probably above my pay grade mechanically to be honest, my days of crawling around under a van into the night doing my own repairs are hopefully overLooking at some of the posts regarding inlet manifold removal it does look like a bad job, just wondering if anyone has pulled the bumper off and taken all the rads out and then it looks like you will be straight at it, but what sort of job is it to pull all the front end off![]()
Hi, no that was an independent garage. Vw would charge probably £1500 as conservative guessHi was this price quoted from a main dealer?
Easy to take all of that off with the rad in place m8 not had the chance to find out with the mpg as the new turbo failed it dropped a shaft nut so back to square 1This is probably my next job on the van, I’m planning to take the bumper and rad pack off as I’m going to be removing and cleaning /replacing the EGR valve, cooler and pipes while I’m in there.
I need to make sure it closes before it’s mapped shut.
Is there any noticeable difference in how the van feels & drives? MPG improved?
