infotainment system
toonaroon
Hi, just wondered if anyone else had experianced this problem?
The display screen on my infotainment system has started to develop a mark in the top right hand corner of the screen and it seems to be very slowley getting bigger ( like ingress of moisture) although there is no moisure whatsoever in the cab area, also the screen has never been knocked (not to my knowlege!!!)
I would be most greatful if anyone knows what this could be, and a possible fix!!
Many Thanks
Anthony
Possibly the LCD structure has ruptured?
Fix? Suspect you need a new LCD screen.
Thanks Bav,
When the screen is on you can't see it, but that sounds very likely so will look into it.
Reactions: Bav
Difficult to tell from the pic but it looks as if there might be a screen protector on there. If so it is probably just a bubble underneath.
Exactly what I first thought, and I am a devil for leaving screen protectors on most electical gadgets, but unless I am completely in the dark that they are fitted from new, I'm sure that is highley unlikely, but thats what it looks like...
