I am trying to wire up a solar controller inside my camper and run a lead to a point at the back so I can plug in my suitcase panels as and when required.
All is going well so far but I am struggling to find an easy solution to the connect/disconnect plug and I have butchered so many MC4 and Anderson plugs trying to find a way that I am about to rip it all out…..
My thought is that I use a domestic 13amp plug with an Anderson on the end where the solar connects into the camper together with a 13amp socket as this will a)fit, b) be neat and tidy, c) be switchable and finally add in an additional fuse over and above the ones I fitted at the battery end.
so after all this waffle I would appreciate your thoughts if this idea is stupid or ok and I thank you all in advance @Dellmassive
