Hi,
Looking for some help; hoping someone has had experience of this & can give me pointers.
Just gone away for a trip & the Tailgate has stopped releasing from the outside (2017 Caravelle).
Electronic switch, and mechanical override on inside of tailgate are both working (I'm having to climb into the boot over the back seats to open it everytime!)
I did pop out the rubber from under the external handle & was a little damp inside (likely from washing ahead of the trip).
I left rubber open to let it dry, this did fix for next few times opening the tailgate, then stopped again!!
Middle 'boot' button on keyfob doesn't unlock the tailgate either - but never has (since i bought it a year ago).
Look like I need to check the microswitch (jumping/shorting it with a piece of cable) & possibly replace the assembly/switch.
2 questions...
1. To get to the internal switch assembly, I have to remove the plastic internal panel/card from the tailgate. Looking for tips on how to do this (can't find anything on here/youtube).
- Caravelle so seems to look a little different to Transporter tailgate - see photo
- Need to remove surround from 'child lock' switch (looks like 2 pin holes to do so - is this a special tool?) - see photo
- Wanted to check if there is a specific process/knack to this before I start yanking out clips/brackets/breaking things...
2. Is there anything else I'm missing, that may not be the microswitch?
- Wanted to check before I start yanking out clips/brackets/breaking things...
Let me know if anything else I need to share alongside all this...
Thanks in advance!
Duffer.
2 questions...
Thanks in advance!
Duffer.
