Help Needed AdBlue (DEF) issue
Kev63
Please advise if you can. I hit the road early yesterday(Saturday) heading for Spain. 680 miles in halfway dow France the AddBlue dropped from 4000 miles to 650, telling me I have 650 miles before the engine wont't start.
I pulled off the motorway and found a campsite, van's converted to a camper to see what I can sort out.
I have read that this can sometimes reset it's self? Is it ok to keep driving or do i have to find a dealer. My van is a 2107 150 with 42K on the clock!
Need a software update, but might sort itself out, did you fill to the indicted maximum, or did you brim it?
No, followed the the amount which was 1.5 gallon, so 6.8ltrs… I’m hoping to find a VW dealer in the morning… hope they sort it… or I risk it and keep heading for Spain
Update… tried to get into the local VW dealership who wouldn’t look at it.. so had to go 100k to another dealership. Half way there, after ragging it on the toll road the warning goes off and AdBlue rehang back up to 5000 miles… so currently sat on a campsite in Spain feeling on top of the world…
How does one go about getting a software update? I think I have the same problem with my van (intermittent adblue fault), but when I called VW to ask if they could update the adblue system software when I bring the van in for a service they said they'd only update if it was part of a recall and there weren't any outstanding on my van. They said they could do a diagnostic which would be £180 straight away, no thanks...
Is it only VW who can do updates through ODIS? or can reputable tuners do them as well? I was thinking of getting a remap anyway so could be done at the same time?
Sorry to hijack Kev63 - glad yours is ok again!
VCDS log:
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 3771
Revision: 23002001
Coding: 00254014432401090000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
ROD: EV_ECM20TDI03004L906056KE_004.rod
VCID: 7CA1F95C866E9D7BBBB-8028
VINID: 9E606AAAA1D8A9A60014204724B8EAFDBB
4 Faults Found:
33262 - Reductant System Performance Bank 1
P204F 00 [096] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [104] - Efficiency too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 116673 km
Date: 2055.01.27
Time: 04:55:45
Engine RPM: 2029.25 /min
Normed load value: 75.7 %
Vehicle speed: 112 km/h
Coolant temperature: 90 �C
Intake air temperature: 15 �C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.281 V
Unlearning counter according OBD: 40
Air mass at air mass meter 1: 208.8 kg/h
Outside temperature sensor 1: B1: raw value: 13.0 �C
Mass airflow sensor 1 bank 1 airflow: raw value: 860.6 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 55.05 %
NOx sensor before SCR cat conv: offset correction factor: 0 ppm
NOx sensor after SCR cat conv: offset correction factor: 136 ppm
Reducing agent quality sensor: urea concentration: 0.00 %
Reducing agent quality sensor: raw temperature value: 0.0 �C
30540 - Throttle Position Sensor (G69)
P0121 00 [032] - Implausible Signal
16230 - Control Module for Instrument Cluster
U1019 00 [032] - Missing Signal for Oil Level/Temperature
[Instrument cluster control moduleMissing signal oil level/temperature]
They will only do the update if you are having problems. That’s what 2 dealers have told me.
Sorry to jump on your thread, I'm having some issues with EML and P20EE every 1k miles or so, Got Carista coming today so I'm going to see if it tells me the software I'm running as I recently booked it in for a DSG oil change at VW for the 1st December and they said it had a shed load of recalls overdue (its never seen a VW dealer in its 6 years on the planet apparently, service history shows local and company stamps). Its also going for a service at a VW specialist on Friday so going to leave the EML on and ask them to scan it but I'm hoping in a way its the software that was never done on it and that is part of the recalls (its a 2016 150) if not i might ask for it even though that will wipe my map.
Reactions: Ows
