Hi,
I have installed H7 headlights so now I want to make my dips come on when the mains are on. According to the information on the forum, this involves:
Module: 9
Byte: 22
Bit 1: Turned off
However, my Bit 1 is already off (and the dips definitely aren't coming on with the mains). My configuration for byte 22 is
Bit 0: 1
Bit 1: 0
Bit 2: 1
Bit 3: 1
Hex: 6D
Now, if I set Bit 2 to 0, then it has the desired effect of turning the dips on with the mains. Flicking the state of Bit 1 has no discernible effect. However, this appears inconsistent with all the information I can find online. Should I just do this and forget about it? I assume that each bit must map one to one with each function change or could it have unintended consequences?
My base vehicle is a Window Van (as it came straight from a camper converter) rather than a panel van - maybe that accounts for the difference?
Thanks for any help!
Tom
Module: 9
Byte: 22
Bit 1: Turned off
Bit 0: 1
Bit 1: 0
Bit 2: 1
Bit 3: 1
Hex: 6D
Tom
