[GUIDE] How to remove a sliding door on a T6
Hi all. Hoping someone can help. Do you know where I can get replacement bolts? The heads are rounded on mine so I need to drill them out and replace.
Make sure you are using an XZN bit and not a Torx bit.
Replacement is just a generic screw with a pan head / dome head, nothing special required.
Yeah it's not engaging with the rear one though, still a XZN bit
IF your sure that its the correct bit then have you tried tapping it with the hammer ? A bit of shock treatment and makes sure the bit is seated correctly. 🔨
Yeah tried that, it just won't grab it, its weird!
