Ollyboy61 Member VIP Member 13 May 2021 #1 ... can anyone advise overall diameter of wheel plus tyre to lift body but not rub on arches ? ⛰⛰
Village twin turbskies VIP Member T6 Guru 13 May 2021 #2 Not sure it's quite so straight forward, as you need to think about over gearing, which will be impacted by which engine you have. Also depends on what suspension you are running (or plan to run)
Ollyboy61 Member VIP Member 14 May 2021 #3 .. I was hoping for a quick height gain using only wheels and tyres, wasn’t planning on replacing original suspension. T6.1 150HP on a 2020 plate
russvphoto Member VIP Member T6 Pro 14 May 2021 #4 My T6 van came from Leighton vans with 275/40R 20 tyres and this gives a 1" lift. Same power as yours.
Ollyboy61 Member VIP Member 14 May 2021 #5 russvphoto said: My T6 van came from Leighton vans with 275/40R 20 tyres and this gives a 1" lift. Same power as yours. Click to expand... Cheers Russ .. i assume not off road wheels and tyres ? Do you have a clearer pic ? Do you experience rubbing on the arches ?
russvphoto Member VIP Member T6 Pro 14 May 2021 #6 Just road tyres, no rubbing even when it was on 40mm lowering springs. Back to standard springs now. 30cm from road to bottom of the sill. Attachments 1D6E7E54-B771-4912-B80B-DED39E1B6072.webp 154 KB · Views: 7
