Ground clearing
Ollyboy61
... can anyone advise overall diameter of wheel plus tyre to lift body but not rub on arches ? ⛰‍♂️
Not sure it's quite so straight forward, as you need to think about over gearing, which will be impacted by which engine you have.
Also depends on what suspension you are running (or plan to run)
.. I was hoping for a quick height gain using only wheels and tyres, wasn’t planning on replacing original suspension. T6.1 150HP on a 2020 plate
My T6 van came from Leighton vans with 275/40R 20 tyres and this gives a 1" lift. Same power as yours.
Just road tyres, no rubbing even when it was on 40mm lowering springs. Back to standard springs now. 30cm from road to bottom of the sill.
