HI All
I've nearly completed my T6 conversion. one question i have is the battery, fuse box, and charger are located in the rear of the van in a cupboard only accessible from the rear doors and then pushed as far into the cupboard so is near the rear middle of the van. the only location i can fit the small camping gas bottle is in the same cupboard as the electrics but right by the rear doors (electrics and bottle are about 1.5 ft apart)
I'm looking to cut a ply sheet to section off the electrics and make them hidden. from a safety point is having the gas and electrics technically located in the same cupboard ok? If so/not what would you advise on where to locate/ what to do with the bottle as space is extremely tight would a drop vent solve this issue?
I have not cut the rubber pipe to size so could either fit the gas bottle in the higher cupboard, or try and route the rubber pipe underneath the rock and roll bed to the other wheel arch
