Hi,
I have a small fuse box under my drivers seat. The plan was to have a 10mm cable (from leisure battery) as the input, and have two outputs- one 6mm/15A connection to the fridge and one 10mm/30A connection to the rear fusebox. I have realised that the 10mm output requires a female spade/blade connector however these do not seem available for a 10mm cable.
Can anyone recommend the best/neatest way to fuse the two output cables...maybe a busbar with inline fuses instead?
Rob
Rob
