Hi All.
Need some help. I am looking to get a Propex Heater installed in the Kombi using the OEM parts (outlet vents in B-pillar, recirc in the drivers door step) supplied by @Pauly. We have everything we need, however we have some uncertainty over the front step.
So the question is:-
Do you have a KOMBI/ PV that uses the aux heating system? Can you tell me if the front step (which is a Caravelle item) has the oval Velle step light, or the square light, like that which is located in the rear step of the Kombi/PV (clearly the Kombi does not come with front step lights, so this is something that will need to be wired in, hence the question so that we can get the correct unit)?
Thanks in advance DaveyB
