Fault code P2017
Trym
Hi,
I have a VW T6 2016.
I had problems with the intake manifold (Code P2006) and it was replaced with a new one. But now I get the fault code P2017.
Can anyone help me with a solution to this problem?
is it possible that it is the solenoid valve that is broken?
Greatly appreciate any help!
Hi,
Please post full engine section of the scan - lessens guesswork what engine it's all about.
Anyways, usually the fault code indicates missing earth (negative) connection - thus a wiring fault.
Hi did you find out what was wrong. Have just gotten the same error codes. First got P2006 and have replaced the entire manifoil with all the sensors that were on. Then I got the wrong P2017 that I haven't gotten before.
Have a volkswagen Caravelle (multivan) 2016 T6
Hi,
Hi,
Did you get to the bottom of this problem. I've done exactly the same and got the same error code come up.
Hi,
I'm having the same problem. Has anyone been able to fix it?
Thank you very much.
Caravelle (2017) 150 HP CXHA 151,000 km
