malvinperrin
Hi,
I have some Problem with my T6 2.0 tdi 150hk 2016/17 model, 4. motion. km 313.000.
fault codes I read is :
- P0332 Ignition/Distributor eng. speed inp. circu - no signal ( tried to replace crank shaft sensor but still same problem)
- P2463: DPF soot accumulation 1.
- P24C6: Particulate matter sensor temperature circiut.
- U112300: Can-buss fault: After delete fault code this never comes back...
Sometimes when I try to start the engine, I have to crank it for a while before it starts. And when it does start, it runs at around 1203 rpm regardless of whether it’s cold or warm. It also feels very sluggish. It takes a long time to reach 80–100 km/h, and it can’t go faster than about 110–120 km/h.
any suggestions as to what could be the problem here? maybe som faulty/broken wire? Does anyone know where the normal place is that a cable can become worn/damaged?
