ESP deactivation/activate with OBDeleven?
cordoba110
Does anybody have the long coding to activate/deactivate ESP in OBDeleven?
I have a long list of codes but nothing for the ESP function.
My T6 doesn't have a button on the dash to enable/disable the ESP like some versions T6 have.
I would like to disable the ESP in snowy conditions. Currently the ESP intervenes so much that the power cuts gradually to zero which leads to a halt. In that case, I can floor it without making any revs at all.
I am aware of a secret manual shutdown for the ESP but this doesn't do the trick. That is to say, this secret manual handling seems to work at my car, the light of the ESP comes on but as soon as I drive away the system engages automatically again.
The secret manual ESP shutoff handling:
1. Turn on ignition
2. activate warning signs
3. press speed pedal 5 times
system ESP shuts of/on
Not sure if the full ESP has been disabled - or even desired to. Meanwhile, the traction control button has been retrofitted. Anyways, posting full VCDS/OBDeleven scan would always be useful to attract attention.
Hi!
I have a Caravelle T6 150 TDI 4motion (2016)
Since few year I'm looking to really disable the ESP.
The button only stop the ASR (anti spin).
I know the trick with contact+warning but I really would like to be able to stop ESP during driving, with the button.
Few years ago I found this : Leon Coding and Adaptations | OBDeleven
But I only have a VagCom.
So in 2021, is there any possibility?
Mmi, I'm in Lapland :waving:
Hi!
ESP(ESC) OFF is not possible on T6 MK100 ABS via coding modification.
Reactions: mmi
