rudzionek26
T6 CXHA engine, 2017, 150 hp
I have a problem with the engine's oil pressure. While driving, the engine runs fine, and it runs quietly, but when I give it some pressure and then slow down and drive, around 2000 rpm, the oil light and warning light come on. I think the low oil pressure sensor might be faulty, either a green or brown sensor, meaning a brown sensor, or the oil pressure valve.
The pressure gauge showed at 80 degrees:
Idle 1.1 bar
1500 rpm 2 bar
2000 rpm 2.2 bar
2500 rpm 2.5 bar
I'm wondering if the valve is stuck in the low ECO pressure position?
I did the VCDS valve test and it came back positive!!
I think I'll buy two sensors plus the valve...
Have you done this?
VCDS error
16058 - Oil pressure switch for reduced pressure. Oil
P164D 00 [01101100] - Malfunction
Intermittent - Confirmed - Tested since clearing error codes
Idle 1.1 bar
1500 rpm 2 bar
2000 rpm 2.2 bar
2500 rpm 2.5 bar
Have you done this?
VCDS error
