Evening all
I was doing an engine oil and fluid check today, and remember some on here suggesting that a blocked / dead PCV would likely be causing a proportion of the engine oil consumption.
So i googled it, googles AI thing suggested I remove the engine oil cap with the engine at idle, stand that there should be a slight vacuum, unfortunately there was no vacuum whatsoever, there was pressure pushing the filler can out of the hole.
So my question… how much of an arse is it to replace the valve cover?
I know it’s already weeping at the rear and that the PVC is an integral part of the valve cover, so I don’t see any point in doing the job twice, especially with all stuff on top of the engine.
