Hi, I've got 17 plate 2.0L Diesel (CXGB) T6 that has decided it doesn't want to start now. There's no fault codes coming up. I suspect the HPFP is to blame. I've got a known EGR valve fault that's been on my to do list to fix, but I don't think this is causing the starting issue. The EGR valve is shut during start (2%) but only opens to 66% when commanded. I believe this is what's giving me a recirc flow DTC.
I've just done the fuel filter, turns out it hadn't been done since 2017 courtesy of the the previous owners. I had an injector fail a couples weeks ago which I thought was a one-off, so I replaced it and coded the new one in. Didn't think much more of it. The van stalled a week after randomly. Soon after that it ran rough and then died completely whilst driving later that day. Now I think it might have been caused by the HPFP degrading. Possibly starved by a blocked 8 year old fuel filter. I'm now getting a some weird readings with the fuel rail pressure which I thinks might be causing the ECU to abort the start. There's a active warning for Sporadic reedings in the engine. I'm only getting 270 to 360 Bar on the fuel rail, granted it's only turning over at 220ish RPM.
I've attached some log csv files and the block file for some logs I did today and I'm hoping to get a second opinion.
I'm going to source a new pump and EGR this weekend.
I'm interested to hear if anyone has seen the same or similar issues?
Thanks.
Thanks.
