The only electrical connection to the HPFP is the fuel metering valve.
Thanks, is that something that can be logged at all to help see if it's working correctly?
One for @mmi I reckon, I have no idea. I don’t remember reading of any previous cases of fuel metering valve failure.Thanks, is that something that can be logged at all to help see if it's working correctly?
The rail should stay pressurised when the engine is stopped.Thanks, that's really helpful. I've just been studying the fuel system diagrams provided by @Dellmassive and I can see exactly what you mean.
Given the intermittent nature, you think it's safe to assume the HPFP is good? No potential issues with the drive mechanism that could be causing it?
Once it's running, it runs fine until the next time it has to try and start.
800 kPa is 8 bar, not adequate fuel pressure for running as far as I’m aware.
The HPFP can deliver up to 2000 bar dependant on engine load.
A leaky or sticking injector could cause the no start.
If one was leaking derv into a cylinder, that would cause low rail pressure.
But probably cause a lumpy crank due to fuel in cylinder.
Possibly white smoke at start from extra fuel?
I thought it was odd in the logs to see the fuel pressure value drop to 0, is that even a valid value?!?:
When engine is stopped the pressure reading is simply next to none - e.g. in post #14 the pressure reading was just fluctuating from 300 to 900 kPa. I'd say none of them is exactly accurate - just sensor's imperfection. Actually in the full log there were also value 0 recorded.Is the fuel pressure value relative to atmospheric pressure? If so, zero would make sense as a value in itself but I gather from previous logs provided by @mmi and @Dellmassive that 300 kPa is the expected value when the engine is stopped.
Injectors can bleed also on the "other" side - returning fuel back to tank. E.g. hereSo if an injector is stuck open the pressure won't build as the fuel will bleed into a cylinder.
That's interesting...Earlier today I was monitoring the fuel pressure when the stop start kicked in and I noticed that the fuel pressure didn't drop.
Having the heater set to max can disable SS so the next time you stop just turn the heating right down to see if it then kicks in.
