Hi , I’ve the same p24a9 fault and it’s over heating , it’s like the pump isn’t either working or no coolant is getting to the pump , I’ve checked all the fuses and wiring , and even replaced the egr cooler pump , scratching my head , any ideas
Hi, can any one help?
I have a P023B charge air cooler pump control circuit low and
P24A9 EGR cooler coolant control circuit low flow.
it seems to have appeared a couple of weeks after the cam belt was changed and the coolant was topped up.
Any ideas please.
cheers,
pete
Hello brother ,my t6 today is same with you the code p023B and p24A9.
I just finished referring to your paper, and I also found that fuse #27 in the fuse box was blown. I'm very grateful for your sharing. Thank you.
Hello Shaw
I'm having the same problem as you. I've tried replacing the fuse, but it still blows. I've checked the wiring of both water pumps, and it looks neat. I've also tried unplugging both water pumps, but the fuse still blows. So, could you please tell me where you found the short circuit? Thank you.
