So with the current situation my camper isn’t coming out of the garage much which has made me think about maintaining the starter battery.
I already have a Victron 30a charger to charge my twin leisure battery setup but have been thinking about changing it for a triple output Victron instead. My thinking is one unit will keep both starter and leisure charged and be able to monitor them with Bluetooth. This would be useful at home but also when away actually using the van as normal. I have another use for my existing Victron so that won’t go to waste.
So my query is the connection, I already have 10mm cables to the starter battery from my DC30 B2B charger, these could be used for the purpose of reverse charging the main battery I would just need to add a connection back to my new Mains Victron charger. But if I were to do that would the B2B charger get confused and try to charge the leisure batteries thinking the engine/alternator is running?
The DC30 doesn’t use an ignition feed to run hence why I think it may cause an issue. Other option is to add a decent size relay on the battery side of the DC30 switched via an ignition live, stopping any connection to the starter battery when on hookup.
Long post, sorry! Anyone thinking about/done similar?
