@JoshBT6
@Ads_Essex is a good list. However I would change it just a bit, however its not a hard and fast list, it partly depends on how long between stages and which part you need to use most:
- sound-deadening and insulating.
- fitting windows.
- fitting a DC-DC charger with L/B.
- running electrics to where you’ll want them. (think about if a pop top or not. I have spoke to converters who say they have to redo all the electrics because people ran them across the top from one side to the other.)
- fitting a poptop.
- carpet line
- fitting a rear floor (OEM rubber mat is the best bang for buck sound deadener and underlay). I doubt you could fit a ply floor over rubber mat so thats a consideration.
- fitting a gas, diesel or electric heater.
- fitting a seat or bed system (Rock n Roll on rails is the top choice for practicability - fitting this alongside your floor will be most efficient, fitting after the floor is down is doable, fitting once you have furniture on top of the floor is aggro).
- fitting furniture.
This is not the order I did things, or the order a converter would do them in, or the order I would do them if I did it again, but possible the easiest/must usable if converting in stages.
