Surfer
Morning!
Installed my leisure battery under my seat with a split charging system (CTEK) other than those items with an isolation switch (accessible from the under the front of the seat) there is not much room for anything else, so far so good.
I need to bring that power out and will distribute via a separate 12v fusebox etc however my van is very much in the build phase (from a panel van) and I want to somehow present that power at the back of the seat in a way that I can put the seat back in place then make the connections later (when I am adding my furniture) to an Inverter, my 12v board as well as an IN supply for an charger when I have an external power supply.
I suppose my question is how do I present this at the back of the driver seat in a way that gives me access later??
Des
Des
