Digital Speedo Coding With VCDS
Hi,
Having trouble coding my 2019 T6 Highline for the digital speedo
Allows me to pick ROW or Australia through long coder helper but on exit from helper new code is there but when click 'Do It' will not accept it
Have tried all other countries but the same response
Am using a old version of VCDS ( 14 ) not sure if this is why it wont allow me to change country ?
Any thoughts please, thanks
What's stopping you from updating your VCDS software?
Your cable may not work with the van. The cable that worked on my 68 plate van wouldn't work on my 19 plate van. I needed to buy a new HEX-V2 cable. MY19 saw quite a few changes and older VCDS hardware would no longer communicate with it.
That sounds about right, in for a service in June hopefully get it done then, thanks for the info
Spot on comment above, got the newer cable and digi speedo enabled also able to get rid of the bulb error light also
