Completely out of ideas and need some help
Jack her up and check for horizontal and vertical wobble to rule out steering assembly issues? All ARB bushes are firm and in place?
Good morning:) ARB's front and rear also replaced with Whiteline ARBs and bushes. I will double check the bolts once the van is up
Did you have difficulty getting the driveshaft back in position when refitting the struts? Not uncommon to pop the inner joints apart. I'd be pulling the joint boot back and having a look. It sounds very likely to be this
No difficulty at all. It can go back only one way if the three slider wheels ( or whatever the called) are lined up. However when the driveshaft was off. One of those wheels come off too. But I just put it back when I was refitting the driveshaft
I'd be looking to recheck things there first
I would also try and "borrow" some standard size wheels to eliminate the new 20 inch wheels. You will definitely get more impact of any issue with bigger wheels, which may have been pre-existing but not as noticeable with the standard wheels?
I took it on a little drive. The issue only exist when the van under acceleration and above 35mph. When coasting even with 60 mph no issue at all. Definitely not the wheels
this thread may be of some help...
Thank youGuys all the clues and the input. On the way back from a test drive i heared a large pop like sound that followed by a large knocking noise every time I hit a pothole.
It came from the N/S that I did not worked on. So focusing to checking the O/S and ignoring the other side was a mistake .
There is a huge play on the N/S driveshaft inner joint. It seems I am having fun over the weekend. Earliest day to get parts is Wednesday.
Brakes are OK. MOT was easy, wheels spinning freely and no warming issues.
Do you really have a V6 engine? My plan is to put a R32 engine in mine at some point.
Yes mine is a factory 3.2 v6 not many around apparently. I sold my t4 was looking for a t5.1 caravelle but got put off by talk of bi tdi issues so decided to get a vr6 t4 and while looking for one I found the 3.2 and it was the best of both worlds. I don’t do loads of miles so the mpg doesn’t bother me (23 on a run 19 round town).
I think a conversion would be really expensive! I’ve found so many things are hard to find for mine and it’s a factory car. I can’t get an exhaust from vw so need to get a custom one made, when I replaced the brakes no one knew what size they where of what the part numbers should be (turned out to be the same as a Touareg). God knows what the gearbox or clutch would cost if they ever go wrong.
Enginewise I think most R32 parts are the same, the difference on the T5's engine is the manifold. I would not mind custom parts as I plan do a super strong engine with custom manyfold , turbo and exhaust system. Got upgraded brakes already. I will make it compatible with my the QD500 geaerbox.
I got the plan, but lack of knowledge and mone yet :D I might have to hire somebody to do the electric work, but one day I am sure it will be done. I would love a V6 T6 Caravelle with 600++ bhp
