My original ABS module died after a dead battery and none of the data was recoverable, I have sourced an identical 2nd hand part, installed it and replaced the brake fluid. Initially after install I had the mismatch of coding data error code however I have updated the coding and this is now away (I think) but have still a few error codes to resolve. Is there any background calibrations I need to do such as steering angle reset etc
Im new to the VCDS side of things having recently upgraded from Carista Pro, I am more than comfortable doing the hands dirty side of things however some guidance would be appreciated from the diagnostic and VCDS perspective
Below is the scan data I have from last night (taken with ignition on but engine not running)
Code:
Saturday,18,October,2025,22:01:44:43745
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZJH011183 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJH011183 Mileage: 95820km-59539miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 6166
Revision: 23002001
Coding: 00194014432401090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004012
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 015F8CBCF183A41281D-8054
VINID: 9E606AAAA1D8A9A6000410480C79BE7C8D
1 Fault Found:
25126 - Implausible Data Received from ESP Control Module
U0416 00 [00100011] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 95829 km
Date: 2093.01.20
Time: 10:24:09
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 18 °C
Intake air temperature: 10 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.140 V
Unlearning counter according OBD: 40
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status: passive
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 60987000000717
Coding: 557E40986563847FAA76027EA685219679F100
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4A44C7F712E2B79-806A
1 Fault Found:
8324 - Databus
U1122 00 [10001001] - Implausible Message
[ACAN: LW1_ID wrong value]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 130
Mileage: 95829 km
Date: 2025.10.18.
Time: 10:24:08
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 20051713470678
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F740807DDBEAFCF-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [00001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 130
Mileage: 95829 km
Date: 2025.10.18.
Time: 10:24:07
Voltage terminal 15: 12.10 V
Voltage terminal 30: 12.20 V
Terminal 15 status: On
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 72BDD370C4258F8A887-8026
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 143170471
Coding: A0FC793A2A61341393284F646CEB8EF40D84718960CC6D603304003F0840
Shop #: WSC 02737 022 1663437
VCID: 2B030E14230F9E420B1-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 300517 04 42 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU001061771528491
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 003 0653
Serial number: KU0KU024051771441669
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 46170001397220107212
Coding: B0FFFF
1 Fault Found:
04194 - Vehicle Status with Under-Voltage
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 130
Mileage: 95829 km
Time Indication: 0
Date: 2020.03.10.
Time: 10:24:07
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32931710800558
Coding: 108008
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 43D346B4AB1F7602D31-8016
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 2405170438A0C8 Dataset Number: 7E0114v____ 0009
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 36352F60E8CDD3AA64F-8062
3 Faults Found:
1058 - Databus
U1123 00 [00001001] - Received Error Message
[FAULT_CIS_ECD_NOTAVAILABLE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 95829 km
Date: 2025.10.18.
Time: 10:24:07
Control Module temperature: 18 °C
Voltage terminal 15: 12.0 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 95829 km
Date: 2025.10.18.
Time: 10:24:07
1037 - Databus
[FAULT_CIS_QDCACC_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 95829 km
Date: 2025.10.18.
Time: 10:24:10
Control Module temperature: 19 °C
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V30051CR$ Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D3B50DCD537CA807-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 440B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042307
VCID: 6889B118F279755A263-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DCB10ECF5474A307-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0449
Serial number: VWZAZ2T5237625 Dataset Number: V03935264QL 0001
Coding: 065700013C00000011111101008808001F0100C6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2517F82C456BA832DD5-8070
Data carrier:
Subsystem 1 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
Serial number: --------------------
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B1A74
Shop #: WSC 00046 000 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 758857000017052601C6
End----------(Elapsed Time: 01:55, VBatt start/end: 12.1V/12.1V)-----------
------------------------------7 Faults Found-------------------------------
