Yes, this is correct.Just got my t6 it’s had cobra springs fitted all round on the rear the coils in the middle are all touching each other is this right
That does not look right to me.
Hi thanks just put a pic on for you to seeIf you can post some photos it would help people offer advice.
Pete
hi yes was level in a garage over the pit and that was how they were sitting but was told from the person I bought it from said there is nothing wrong with them so I have now changed them for original ones . Many thanksAssuming the vehicle is parked on fairly level ground in the photo, the spring cannot perform its function, i.e. to compress, so no, not right, not right at all!
This is correct.
Correct or not, the middle coils cannot be compressed because they're coil bound even on a stationary vehicle, (I'm assuming there's not 900Kg in the back of the van!) therefore they can't do their job. I can't see how the small amount of flex provided by the coils at the top and bottom of the spring can offer much in the way of travel, the ride must be horrible!! If it were my van they'd be heading for the bin!This is correct.
The middle coils are wound to be weaker and the outer coils are wound stronger to hold the van up.
Lowering springs like this are ok to get the van lower, but don't give a very linear axle movement.
You'll see from Dellmassives photo, that the Eibach -30 springs are not coil bound and as such, give a much more linear and smooth axle travel.
The H&R springs are the same, and that is why, when fitted to an empty van, you get a knocking noise.
The only way the springs can offer more travel when fully compressed is to have less coils, this is the case with the genuine and Eibach springs and why the travel is ramps up slower.Correct or not, the middle coils cannot be compressed because they're coil bound even on a stationary vehicle, (I'm assuming there's not 900Kg in the back of the van!) therefore they can't do their job. I can't see how the small amount of flex provided by the coils at the top and bottom of the spring can offer much in the way of travel, the ride must be horrible!! If it were my van they'd be heading for the bin!
