Clock on radio display
Ah! I wondered if you men would spot that. Really! Surely not. Presumably all the respondents to T6 forum, who have the clock problem, all have a variety of vehicles with slightly different head units. Perhaps there is someone out there who knows the answer.
there is talk of correctly signed firmware and dodgy unsigned firmware however i have always found MIB solution and the other main site to be pretty reliable. Now there may be a route to take in the upgrade path i.e. you can't go straight from 2xx to 3xx as an example. I have an older headunit in my 2015 tiguan 2 SD slots (media) looks the same layout as yours and i had to fudge the upgrade path to allow me to get to the higher numbered firmware as well. i am lucky i have VCDS and can enable the developer mode menu on the head unit. it was a long time ago but the how to was easy to follow. I will see if i can find the link.
i know some are not tech savvy and it might blow your mind but it might help if you have clever kids lol :cool:
OK, i have read what i did and it would appear i went from 241 to 253 without issue then i did some magic and got to 478 (needed developer mode and file patching). I know going outside the 2xx family i lost my wifi.
I had this, slightly older sw version by the looks of it. Mine went wrong but that could’ve been something I done, I dunno I’m a bit puzzled by it really as others have done it no problem
If you can get someone with VCDS to get the headunit into developer mode, there maybe an option get a recovery loaded. I haven't done it nor connected physically to the headunit so its all at your own risk in terms of recovery. it can be done if you follow the how to's, i appriciate theres some soldering required and pulling out the headunit.
did anyone upgrade to the latest firmware? i.e. 480 ?
and don't forget your CPU is also 10 years old or so.
Can the CPU be upgraded???
I have now been trying for two weeks to upgrade my software. Is it really possible, or is this just a cruel hoax? I am sure that I am unzipping a file, and getting it onto a brand new memory card. But when I put this in the van slot it tells me that there is no software on it. Can anyone tell me, does this mean that it is not finding any software at all, or does it mean it can’t find appropriate software?
it definitely can be done and MIB solution is a reputable source of firmware. I updated a T-Roc head unit without issue just before Christmas, download, unpack, copy to SD card and then update.
Maybe list your start point, file downloaded, operating system, zip unpacker.
just trying to cover all bases.
Cluster Clock and Radio not synced {FIX} + Activate Voice and Carplay/Android Auto​
don't mind me, just spreading this as much as i can on all sites i used to look for answers on.
Hello,
There is a massive issue with volkswagen cars from 2015 to 2020 where the radio doesn't show the correct time anymore and only shows either 00:00 or 06:28. The issue is that the instrument cluster panel time can be set, and on the board there is a chip that communicates with the radio and gives the time to it so it's synced. There is an issue where after a few years a hexidecimal value in the chip goes too high and the chip fails. This could only be fixed by buying an EEPROM CH341A device, dissassembling the cluster and attaching a clamp to said chip and rewriting the hex value on a laptop. A large community of people even started a petition to try and convince Volkswagen to bring out an update to fix it. Some even wanted to start a class action lawsuit. I was scrolling trough reddit to find a fix and luckily i found a person that linked a german forum. It looked complicated at first, but it took me 25 minutes in total. Below are the instructions and the links for the non german speaking lads.
This worked for me, i followed the steps and the video using the correct files. Don't forget your still kinda tampering with obsolete hardware and software and if you use the wrong files or methods you could brick your radio. It is very easy to install, and i made the steps extra clear. You don't need to mess with the OBD port or any chips. All you need is an SD card and a laptop/pc that can read it.
My car: Volkswagen Caddy 2016
I bought an SD card for a samsung camera, and windows only let me format it to either exFAT or NTFS. Appearently these are just windows restrictions and you can still format those to FAT32. Heres a video on how to do that.
And here is a video on how to install the update.
December 25 2025
Hello everyone, VAG has finally taken pity on us and released an update for MIB2 PQ units with the 02xxT software train. In connection with this update and some new findings, we've created a new thread to address the clock issue. Initially, until all the links are collected and available, the thread will be updated several times. So, it's worth checking back regularly. There will be an informational post whenever a new link is added.
The problem in question:
VW, Seat, and Skoda vehicles on the PQ platform that use an MIB2 PQ infotainment system can experience a clock display error. They will only show 00:00 or 06:28 alternately. Additionally, the arrival time from the navigation system (if equipped) is no longer calculated and displayed correctly. To fix this problem, a simple firmware update for the infotainment system, which can be installed via SD card, is sufficient It no longer matters whether you have a navigation system (2 SD card slots) or not (1 SD card slot).
The solution: A firmware update for the infotainment system via SD card.
The required firmware update varies depending on which firmware version is currently installed.
To find out, proceed as follows:
Press and hold the MENU button, then select “Software Update/Versions”.
Here you will find the installed software version.
For a 02xxT software version, an update to 0255T is required.
For a 03xxT software version, an update to 0369T is required (except for Skoda).
For a 04xxT software version, an update to Seat 0478T / VW 0480T is required (except for Skoda).
Example: If "MST2_EU_VW_PQ_P0241T" is installed in the vehicle, this means you should use the VW 02xxT link, i.e., "MST2_EU_VW_PQ_P0255T".
Here is a collection of links for the respective updates. Please make sure you select the update for your specific vehicle (VW, Seat, Skoda).
The login details for mibsolution, if requested, are in the website's "Welcome" window. For those who clicked away too quickly: "guest" and "guest".
VW 02xxT: MST2_EU_VW_PQ_P0255T
VW 03xxT: MST2_EU_VW_PQ_P0369T
VW 04xxT: MST2_EU_VW_PQ_P0480T
Seat 02xxT: MST2_EU_SE_PQ_P0255T
Seat 03xxT: MST2_EU_SE_PQ_P0369T
Seat 04xxT: MST2_EU_SE_PQ_P0478T
Skoda 02xxT: MST2_EU_SK_PQ_0255T
Firmware update installation:
Required:
  • Computer/Laptop and SD Card Reader
  • A good quality, full-size SD card. At least 4GB, 8-32GB recommended. A proven SD card is the silver SanDisk Ultra 32GB. Please DO NOT use a microSD card with an adapter!!! This could brick your radio!
r/Tiguan - Cluster Clock and Radio not synced {FIX} + Activate Voice and Carplay/Android Auto
  • Before starting the update, test whether your touch screen in the upper right corner is working. Otherwise, you may encounter problems confirming and ending the update, as you'll need to tap a back arrow. Tips for when your touch screen isn't working are listed below:
Option 1 (Recommended): Replace the digitizer.
A new digitizer usually costs less than €20 and can be easily replaced, even by inexperienced users, within 1-2 hours (allow time for coffee/tea/beer). Experienced DIYers and hobbyists should be able to do it much faster.
You can find a new digitizer on platforms like Amazon, eBay, and AliExpress. Simply search for "TDO-WVGA0633F00039".
The digitizers usually come with adhesive strips already attached, so you can simply stick them onto the old, defective digitizer.
To replace the digitizer, the radio needs to be removed and unscrewed. Don't be intimidated; the process is quite simple. There are even YouTube videos that demonstrate the whole process. Examples can be found here , here , and here .
Option 2: If you absolutely don't have the patience to "replace" your digitizer, or if the update has already happened and you're only now discovering that the touch screen isn't working, you can try pressing and holding your finger firmly in the upper right corner of the screen, where the back arrow is. At the same time, tap and/or swipe firmly on the opposite side of the screen (bottom left). Sometimes this can trigger a touch response in the desired area. If that doesn't work, try "rolling" your finger slightly in the upper right corner while applying moderate pressure and tapping somewhere else on the screen.
Option 3: If you have diagnostic hardware available (VCDS, OBDEleven, an ELM327 scanner, and the smartphone app "Car Scanner"), you can use an XOR calculator to confirm the "installation change" in the radio's adaptations (control unit 5F). CarScanner has an option for this and can do it automatically. VCDS, OBDEleven, etc., require the XOR calculator. To do this, note down the currently written code, enter it into the XOR calculator, note the new code, and write it into your adaptations.
IMPORTANT regarding step 4 : This is what the main directory of the SD card should look like if the update has been correctly copied to the SD card. Individual folders may differ, but it should look approximately like this.
Tutorial:
  1. Download the appropriate update.
  2. Extract the update
  3. Format the SD card to FAT32 on your computer.
  4. Copy the extracted update to the root directory of the SD card. It is important that the update, including all its folders and the “metainfo2” file, is located in the root directory of the SD card.
  5. Insert SD card into the car
  6. Press and hold the MENU button, then select “Software Update/Versions”. Tap “Update” at the top, select the SD card, then select the update and tap Start, then Next.
  7. The radio will restart several times. Once the update is complete, a list with many entries and "OK" next to each will appear on the screen. On this screen, tap the back arrow in the upper right corner, then tap Cancel. The radio will restart again; after that, the update is complete and the SD card can be removed.
You have successfully completed the update. The time issue should now be resolved.
BONUS:
VW discontinued their key services for the older devices under 2020 (atleast in my country). Currently there is no way to get Voice or Carplay/Android Auto working on these models officially. There is however an easy work around that takes literally 2 minutes to do, and unlocks both those features on your radio. It's literally the exact same update steps as above. Only do it after you updated to that specific version. Steps below.
  1. (Optional): Clear the SD card again, copy the contents of the "VW_PQ_P0255T_FEC_ALL_CID_OFF_FIXED" folder to the root directory of the SD card, start the update in the vehicle, and complete it. -> This step unlocks features such as App-Connect and voice control. It also allows the use of any SD card for navigation maps.
https://www.digital-eliteboard.com/attachments/vw-0255t-patch-0480t-downgrade-zip.231922/
Hello,
December 25 2025
Required:
Tutorial:
BONUS:
all good, thanks, but I cannot find the "VW_PQ_P0255T_FEC_ALL_CID_OFF_FIXED" file
