Changing door hinge on dometic crx fridge
Hi my converter has hung the fridge door on the right which makes it awkward to access. Any idea how I change this to the other side. Note it is already installed making it not as easy as manual suggests. Thanks
Assuming it's the 'standard' Dometic fridge, I'm pretty sure that you gave to get it out to do the job. IIRC you've got to get the bottom bracket off (to put it on the other side) and also access the top two to to swap them over as well because only one of them has the required hinge pin. It. a five minute job once the fridge is out but.................
