Change Air filter on cluster
T6_FunBus
My van can’t go more than a day wothout beeping something at me at the moment!
Inspection - done
Oil change / service - done
Adblu fill up - done
Today it randomly bitched about ‘change air filter’ and a spanner come up on the cluster on ignition on.
I can’t see anything in the cluster that suggest an air filter timer / reset. No errors. Any ideas anyone?
Its running a foam high flow panel filter.
Thanks.
A picture of dash display?
What's shown under: OBDeleven > Control units > Engine > Live data > Air cleaner degree of soiling
Anyways, I would expect there is a fault code in the engine controller. Clearing that perhaps?
Or possibly just the traditional way - unplug and plug the MAF connector next to air filter box - should reset the soiling counter.
EDIT: see post #13 further down.
No errors in obd11
Degree of soiling 122% (whatever that means, not sure how it detects that, I cannot change it).
Currently running a ram-air foam pannel filter, have been for quite a few months.
  • Wow
Ahh can’t attach a video but its literally the same as a service indicator. Ignition on ‘Change Air Filter’ and a gong with picture of spanner. Then disapears - no permanent warning light, no errors in ecu. Cycle ignition, gong and warning again just like it needs a service.
I unplugged MAF and plugged back in, made no difference to this number. Just gave me a load of errors I had to clear as it was unplugged.
Did you unplug when ignition was OFF?
I was working next to air filter box and unplugged the connector (when IGNition was OFF) - to my surprise at next IGN ON there was a fault code AND the air filter soiling counter was reset to zero.
No I tried it with ignition on (engine not running) and engine running.
I was happy today I fixed my last series of gremlins but seems the transporter wants to he a complete diva atm. Couldn’t believe this popped up today!
I’m getting a bit tired of working on it this week, but I’ll go grab a beer, do what you suggested, if that doesn’t reset it, I’ll just remove the top of the airbox and run it open to see if it changes. If not I don’t have a scooby. The MAF appears to be working.
Unplugged maf with ignition off and no difference. I guess I’ll pull the top of the air box / filter next.
You are a LEG-END!
That did it…
Never knew you had to do that, and maybe the last garage that serviced it did not either!
Before I sae your message I just removed the filter and put a fresh cone on it and started - no change. Ran what you said above and…
You guys are awesome :D
The maintenance workshop manual mentions as final step "reset learnt values for air filter in engine control unit" on page 88 in chapter
Well, so I thought. It seems that my assumption was based just on a conincidence. I unplugged the connector for some other work (at 78879 km) and only afterwards looked into measuring values :rolleyes:
Anyways, digged my regular logs and discovered that the behaviour of the "Air cleaner soiling" is quite interesting - it cyclically resets itself. The only time the sensor has been unplugged was the case mentioned above. Even checked when the van was serviced - none of those align with the resets.
The data was extracted from VCDS snapshots made at every fuel fill-up. The air filter still is the original as per VW service plan every 120.000 km or 6 years. The filter was still very clean at 5 years.
Hi all, got this issue also.
Have tried the ODBeleven reset but I get an incorrect diagnostic mode error message on ODB. Tried all the modes still the same. Am I missing something?
Funny you should say that, I’ve no idea if they updated the app, as in the past week I get an error when trying to run output tests that I didn’t before :/
Hi mate, did you manage to reset the value or get rid of the message? Mines just started to do the same! Thanks
Thanks for the reply. I was just wondering if the solution in posts 10 and 11 was still valid as mos4000 seemed to be having issues when he tried to reset them. Thanks
