Carista Dpf?
Minkey
Hi all,
Got a Carista with paid app.
It doesn't have an option to show DPF filter percentage.
Anyone know an app that does? No motorways or dual carriageways near me so good to know when I could do with a long drive...
Cheers...
Haven’t personally seen one that does. I’ve used VCDS and Carista and not see it as an option on either.
theres a great app called vag dpf. doesnt work with all engines yet though so get the free version first to test it then buy the paid for version. works with carista dongle.
I read mine in vcds, just use the measuring blocks.
Found mine
Address 01: Engine (04L 906 056 KP)
10:27:33
IDE00151 Oil fill level 80 mm
IDE00304 Fuel level 70 l
IDE00430 Particle filter: field regeneration request status Counter request active
IDE00432 Particle filter: time since last regeneration 931 min
IDE00434 Particle filter: soot mass calculated 37.78 g
IDE00435 Particle filter: soot mass measured 22.87 g
IDE00436 Particle filter: kilometers since last regeneration 758.0
the vag dpf app is fantastic. alerts when a regen is taking place and is easy to read on the move which vcds clearly isnt.
Found mine
10:27:33
Excellent well done @Loz, didn’t know it was there. Is there two particle filters? Since you have different soot mass readings.
Just one but it has a measured value and a calculated value.
That measured value was close to maximum allowable for a forced regen.
