Shorts2000
Hi has anyone code a new battery in with the new Carista update yet? If so what setting did you use?
Thankyou il take a lookUpgrading Starter Battery - how to guide should give all the info you need
Hmmm. Thanks for sharing this. I’ll have another look.The Carista website shows the battery type as being one of the things you can modify, don't know why you can't.View attachment 188557
I've actually installed the same battery.I’ve just fitted my new Bosch 95Ah battery (S5 A13). Coded with Carista.
My question… why is there no option to change battery type?
Previous battery was a Varta AGM (75Ah).
Do I need to be concerned that the right battery type is coded? Does the van expect AGM by default?
View attachment 188540View attachment 188541
